TwinTurbo.NET: Nissan 300ZX forum - VG30DE engines are interference engines.
RZturbo
on May 28, 2013 at 7:58 PM
Not entirely true
posted by 300ZMang
on May 28, 2013 at 12:43 PM
you must be lucky.
will a broken tiiming belt cause engine seizure?
jjamez
11:14:32 05/28/13
ChaseGrayTT
11:27:33 05/28/13
Do what Chase said
300ZMang
12:24:43 05/28/13
If T-belt snapped, the pistons will hit and bent the valves
RZturbo
12:33:36 05/28/13
Not entirely true
300ZMang
12:43:36 05/28/13
VG30DE engines are interference engines. -
RZturbo
19:58:01 05/28/13
Valves were bent yes, did car run perfect? No....
300ZMang
07:13:24 05/29/13
mine spun just fine. (n/m)
Antihero
13:32:20 05/28/13
looks like coolant in the oil
jjamez
13:05:50 05/28/13
unsure about tension but timing belt not broken (n/m)
jjamez
13:11:22 05/28/13
compression test on 6/2012
jjamez
13:14:50 05/28/13
those numbers are not the worst. (n/m)
Antihero
13:33:04 05/28/13
Looks like your timing belt is off a tooth or two
ZXoltan
13:52:45 05/31/13
timing belt was replaced by shop several years ago (n/m)
jjamez
15:56:20 05/31/13
Sure, and from your original post you have T-belt concerns
ZXoltan
11:07:08 06/02/13
Did you overheat the car?
CameronSF
13:29:47 05/28/13
no, it didn't overheat, just stalled (n/m)
jjamez
13:30:50 05/28/13
